Whatever you do, don’t be tempted by a Garmin Zumo 660 ! Worst piece of cack I’ve ever had the displeasure of owning !! Now have the Zumo 590LM and it’s better by miles...
I've gone for the Quad lock - have used my phone previously with the Maps app and it was fine, so this should be even better. Picking the bike up from Tunbridge Wells on Friday so will definitely be using the nav on the way back.
Most definitely not. Strictly cravendale in our house. Actually 15-20 odd mins from Tunbridge Wells but nice roads in better climate. Hartfield in Ashdown forest.
Not sure if you’re bothering with charging, but if want to charge on the go, you’ll need something like this.
I use a 12v to dual USB converter and have used Sugru to mount them inside the fairing by the top yokes. Shielded from the weather and I run one for phone and one for action cam. JZK® Car Power Converter DC 12V to 5V/ 3A Voltage Converter with Dual USB Adapter Connectors for phone charging car audio radio etc https://www.amazon.co.uk/dp/B06XSCCLCD/ref=cm_sw_r_cp_api_RZWeAbBAT412F
Good idea, thanks. The sat nav does drain the phone battery somewhat. If only i could, would bring on nuclear wind before i got to the bottom of the cup
