Sl Brake Disks
Discussion in 'Supersport (1974-2007)' started by Mr-Superlight, Dec 3, 2018.
  1. Needing to replace the front disks on my SL - the 'floating' aspect has deteriorated to a significant rattle - they're worn out. Option is to replace with Brembo Serie Or - any advice as to y/n? Think they're black carriers as opposed to gold so I wonder if they're need repainted.
  2. get the brembo hpk...
  3. As above, the Brembo HPK are the best. Serie Or are very good though. One thing that does come to mind if you dont mind me saying is are you sure they need replacing? Rattling is a normal thing, usually just needs replacing when they get worn down below ~4.5mm or whatever the figure is?
  4. I've not yet measured the rotors but I can see wear where the bobbin sits in the disk and the rotor can move in every direction which I don't think is right. I'd be surprised if the disk thickness is too low but my understanding is that as the bobbin material is harder than the disk material then premature wear occurs.
  5. Another thing is that many garages have no clue about these type of disks and have, for years, queried the rattlecas indicative of excessive wear. Fortunately I've got a newish guy fairly close to me- North Motorcycles on Edinburgh do I'll get his opinion (was him that suggested using the existing disks for ornamental purposes only now and replacing with Brembos as cost effective).
  6. Is that the guy down Leith way? I've not heard much about him, only been trading a short time. What I have heard is good. Liam Venter did new floating disc carriers for a while but I'm not sure where you would get the outer.
  7. its normally the alloy carriers that wear....
  8. They wear over time but it's completely normal for them to rattle and move around slightly, thats the whole point of them so the pads get a good hold on them. I find it really hard to believe an SL has been been rode hard enough to wear a set of disc carrier bobbins? My 1199S had three years and 10,000 miles of heavy use , 5000 on track, and whilst the discs were starting to get thin they were perfectly useable still. My R has 4500 miles of heavy breaking on Z04 race pads and the discs are fine.
  9. PFM discs....outer is removable making replacement much cheaper (90 quid per side i think) got a set on my RSV4 and very very pleased...ill be buying more for the hyper and my z1000 also.
    Initial outlay is expensive 500 for a pair, but there after nice and cheap....
  10. its an older SL not the 1199 version...:);)
  11. Ah ha... I was wondering too... :laughing:
  12. Mine on my Superlight rattle too. It's correct and to be embraced, it's a lovely jingle and sets the SL apart from the other bikes. :)
  13. im not a detective as you know...but it was posted in the super sport section.:):):)o_O:innocent:
  14. Tyler is the owner of North - really good guy, seems very knowledgeable. Think I'll pop in with the wheel and get his take on it.
  15. Aaah I wondered what was going on! I'll wind my neck in :)
  16. tat versus quality...in my humble opinion of course
  17. I am running these at the moment and been really pleased with the brake power with them. Have not tracked the bike so not sure how they would handle repeated hard use. They are better than the worn out originals thats for sure!! If road is your main use then in my opinion they will be fine!!
  18. Appreciate people's opinions ...
    Took the front wheel to Tyler at North Motorcycles, leith today. In his opinion there is de e wear but not significant and perfectly usable. He eventemoved one if the buttons and checked it and the rotor plus carrier for rear- tiny bit on button and carrier but minimal really.
    One suggestion was to source alternative washers that have a 'spring' characteristic to eliminate a little of the rattle- not sure where I might get these?
  19. Thanks for that detailed info - I've decided that for now there's no need to replace - the rattle is not an issue wrt wear and I'm perfectly fine with it myself.
