Starting Issues 1991 750ss...several Points!
Discussion in 'Technical Help' started by Captkirrane, Dec 15, 2025.
  1. As derick has said you seem to have a bad connection, you should have a resistance of only a couple of ohms between pin 87 and either of the coil feeds
    Check that the circuit resistance goes open when you switch the kill switch off and gives a repeatable resistance when back to run( this gives a quick check of the switch) and check the fuse (2) and the fuse holder for evidence of overheating and corrosion
  2. Ok, so I’ll have a check of the negative cables from the battery and I’ll check the back of the fuse holder.
    can anyone explain what significance pin 87 has with this problem? I’ve look at the wiring diagram but as it probably well known by now I’m not that knowledgeable with electrics. Maybe some understanding may help me solve the issue quicker.
  3. That’s the 12 volt supply to your the majority of the fuses when you turn the key on and then supplies the individual circuits
    This is “switched” with the relay
  4. Should I of done all investigations with the ignition on? As it wasn’t when I metered the connections
  5. No, these are resistance checks
  6. Great stuff, thanks again everyone for the help. I’ll get on with those bits an report back.
    one more thing, on the wiring diagram it shows 3 connections on the battery negative. 1 goes to the reg/rectifier and th other two too ground. I only have two cable terminals that fix to my battery
  7. The battery negative should have one lead that goes to the frame at the LH side of the battery. From there there is another lead that connects to the engine. Somewhere behind the clutch if I remember correctly.
  8. I was looking at the wiring diagram last night and after taking the reading yesterday I was doubting myself to whether the ignition switch was in the ‘run’ position. So I had another quick look just now and carried out the same level of tests.
    So with the the switch in the run position from pin 87 to positive terminals on the coils is reading 0.8 ohms (so I must’ve made a mistake yesterday).
    as I was carrying out other resistance tests I did notice that as soon as I disconnect the plug to the ignition loom the note of the pump goes up.
    I did a voltage test and at the plug to the loom I’m getting 11.34v but to the positive terminal on the coil I’m only getting 10.3 so I’m loosing a volt between those two points.
  9. Sounds like HR or a mild short somewhere.
  10. Go through and clean all the electrical connections. I like to physically clean them using a small wire brush in a Dremel then chemically clean using a contact cleaner.
    Another option is to run a wire straight from battery positive through a fused relay to the coils and use the original positive feed to trigger the relay.
  11. Hi all
    just an update, I managed to source an igniter box from a friend and it now sparks! I only had one so I’ll be getting a pair soon enough.
    I thought I’d see if it started on one cylinder and no joy, but I’m not sure whether it would or not. Though it’s still dropping down to 9.4v on the positive terminal on the coil when I turn it over.
