Streetfighter V4 Reverse (race) Shift
Discussion in 'Streetfighter' started by J0n3s, May 6, 2023.
  1. Hi,
    Can the SF V4 run reverse shift with the standard rear sets or does it require aftermarket bits?
  2. Yes, very easy. The shift rod connects above the gear shift lever as standard, if you look beneath it , there's another mounting point. Change it to there, and you have race shift
