V4 Strong Exhaust Fumes From Akra Full System
Discussion in 'Multistrada' started by Muppet, Mar 12, 2026.
  1. I had a dealer fit the Akrapovic system to my 2024 V4S together with the upmap and ever since I've got very strong exhaust fume smells. This wasn't present before. I was expecting some given the absence of the cat but everything really stinks, clothes, boots, luggage, everything. I can't find any obvious leaks from the system. Is this really to be expected? I've not picked up on anyone ever mentioning this before. Sounds daft but it's really annoying me! If there's nothing else I need to be checking then it's going back in to the workshop..
  2. the bike i test road had a full ackra system and it did have a octane smell but in a good way
    I bought a rally v4 multi with standard exhaust and it has no odours...........except me !
    so your situation would seem normal
  3. Run a 1260 with no Cat and on initial start up it does smell like a motorbike should and expect with more fuel on a cold engine..
    Once warmed up its not really an issue tbh.. might be worth getting your bike looked at/mapped properly/ check what is really happening with the fuelling by an expert.
  4. Stinks when out and about or in general? Could be they knocked a breather tube off and forgot to plug it up again, causing fuel vapours to pour out whilst sat up, stinking (or smelling nice to some) of fuel.
    Else yea, without a cat and a 'full' (OEM headers with the full kits) setup, you'll obviously have unburnt fuel come through a lot more than previously. My 1260 is a bit whiffy and as @Rich4 said, it's normal. As once up to temp, most of the fuel will be burnt up from hotter running temperatures. Physics yo.
    I've removed my EVAP unit as well, which makes it even worse!
  5. @freshage
    What's the advantage of removing the Evap unit?.. just unnecessary enviro clutter, weight, euro regulatory BS? Or cosmetic reasons.
  6. I removed mine to make way for a Denali Soundbomb…something which is much more useful :)
  7. Enviro clutter. However, many (mostly Americans) seem to have problems with the evap canister because they fill their tanks to the brim so it’s almost overflowing. It then does overflow as it gets hot and expands and as they go around a corner and it sloshes about and it fills their evap canister with petrol rather than fumes which then causes issues with the sensor the evap canister. Why they would fill it so full is beyond me but then most things Americans do is beyond my understanding ie fecking stupid.
  8. Is it a tank off job to remove it from a Mts 1260?
  9. Several reasons, it is an ugly box, unnecessary weight to tick a checkbox at an emissions validation during manufacturing, of which I think it was around 400 grams. And as @West Cork Paul pointed out it actually hurts if you're a brimmer which on long stints of back to back fuel stops I do find my self doing.
    There are kits @Rich4, it helps, but it might be possible without. As you can see, I learnt an expensive lesson rushing the job and snapped a breather tube nipple pulling the fairing off at the same time I also stupidly unscrewed the fuel cap assembly...
    https://www.ducatiforum.co.uk/threads/evap-removal.99708/
    https://www.desmo-racing.com/en/jet...onnector-ducati-jpes002-xml-426_641-7308.html
  10. I had the same comments from my friends, particularly when on the Continent when I was running higher "E" rated fuel:) Peter
  11. Different bike but I had similar on my 748, obvs no cat either but there was a small leak between the mid pipes and the headers, I suspect when sat on the bike at standstill I was being lightly bathed in fumes. I recently refitted the stock mid pipe and cans and while the exhaust still smells a bit compared to modern bikes, my clothes dont smell anything like as bad
  12. a V4 multi isn’t going to stay brimmed for very long:joy:
    • WTF WTF x 1
  13. Just turning ignition knocks a bar off the range eh?
    • WTF WTF x 1
  14. You would be surprised how difficult on the nose a bike that’s de-catted is when we have all got used to them running so clean! Plus, Ducati maps are likely quite rich tbh.
    I’d say when warmed fully and with some miles on it if the exhausts are dry and not massively sooty then it’s probably not way off, if you have wet exhausts and the exhausts are black and you can wipe the soot with your fingers after not too many miles then I’d say maybe there is an issue. You’ll always get some residue in the exhaust though of course
  15. Dealer says it’s to be expected as most of the joints are push fit with springs and ‘it’s perfectly normal for a race system’. I emailed Akrapovic and they passed it on to their UK distributor Performance Parts who got back to me pretty quickly saying it really needs to bed in a bit.
    It is leaking I have found, from pretty much every joint. I blew air through the system and sprayed soapy water on the joints and they bubbled. Even the resonator box did. I dunno, I think I’m going to go and see Rick at JHP and ask for his opinion!
  16. id be surprised if it wasn’t meant to be fitted with some exhaust paste of some kind to just take up the air gap and seal it but yeah it will seal with expansion etc I’m sure.
    I’d only be worried if there were leaks near bodywork etc
  17. Dry joints with some leakage early on isn't unexpected.
    Enjoy the smell and just try to avoid quick 15-30 minute rides else it'll never run up to temp and always stink.
