Hi if I fit a Termignoni exhaust down pipes and can do I have to have the ECU changed? or can you run with a standard ECU? if not what does an ECU cost? Thanks
A full system I take it? This set up certainly used to require an upgraded ECU but with custom mapping coming on over the years it may be possible to map your current ECU. Call MotoRapido, they'll put you right in five seconds flat.
Hi thanks for the replies, what about a racefit slip on end can would that run on a standard ecu and map?
