The Cyclists/ebikers
  1. I’ve cleaned the gravel bike as I can’t ride it. The road bike, which hasn’t been used probably since September maybe October is sticking to its high maintenance reputation. Two flat tyres, rear needed the tyre moving enough for me to rod through the valve core. Drive needs a proper clean, which I will start as soon as I can unplug it. Di2 is obviously flat as, but looks to be ok, if it completes charging and the weather stays ok, I might get out later.
    I will phone the LBS tomorrow about the gravel bikes SRAM AXS, I’m hoping it can easily be re-paired as I’m not quite ready for it’s pre LEJOG service.
    It has new F & R pads, I’m hopeless at measuring the chain, but wouldn’t be surprised if that needs changing before I set off.
  2. just buy one on these
    https://hopkinsoncycles.co.uk/produ...bicycle-chain-gauge-measure-stretch-detector/
