The more i look, the less i want to see.!!
Discussion in 'Technical Help' started by densel16, Feb 22, 2014.
  1. If one religiously stuck to that spec, then you'd need a new clutch every few hundred miles... :eek:
  2. or to give the full quote...
    According to the service manual, the gap (S) between the plate tabs (A) and the basket (B) should be less than 0.6mm to ensure rattle free operation... I can see that your gap is *slightly* more than that!!! But it doesn't mean your clutch is knackered, just that it will rattle more...
  3. Got a 3 phase charging system, thank God. plates were ok, charging system is fine, push rod fitted and nichols nuts. got 35mm socket, rebuilt bike, went to Aberystwyth Sun, and now have no chicken strips and in love with the A44 and the A470. Shellgrip heaven. Life is good again. Thanks all for help and advice.
  4. know anyone who sells Nichols flywheels in uk? might be tempted by one with same diameter (and holes to fit my tool).
