The Serious Thread - Archaeology
Discussion in 'Lounge' started by figaro, Sep 29, 2014.
  1. I'm not pulling any legs, and I'm no conspiracy theorist, I don't believe in aliens either. But I think the historians have got it wrong.
  2. dig a hole to the left,push down. insert pivot. fill hole.
  3. still a good thread tho.
  4. Pulleys figs. Pulleys. One of humanities greatest discoveries. A device that trades force for distance.
  5. that sounds suspiciously like sex to me...
  6. you knows it.;)
  7. Yeah but sex with what?
  8. Your going to pull one off while getting an English decorator to use sand paper on it before he gives you a top coat - or did I read that wrong???
  9. And that before I even get properly involved :Happy:
  10. That sounds feasible, if you can lower one end enough to get the pivot close to the centre it would work quite easily.
  11. Im assuming that the rocks were cut from a vertical surface, not a horizontal one. Then pulled out sideways, not lifted up
  12. Right then. How did they drill the holes that are evident at Giza and Puma Punka, to name but two?
  13. No, there are unfinished pieces on site, they were cut out flat.
  14. How about they started to cut them out on the surface, bit like a chessboard for example, cutting down. Then they dug a sizeable trench on one side and cut them out systematically. That would work surely
  15. Don't you need a passport to get on this forum these days?:mad:
  16. Yeah, but it doesn't matter which country issues it :Shifty:
  17. why is every one so quick to dismiss the alien theory?
  19. Again, the unfinished piece (which is bloody huge) is surrounded by a trench no more than a couple of feet wide, and the bigger the trench, the more material you waste. So I don't think the whole lever idea stacks up. I think finm has hit the nail on the head.
