Trailer Torque
Discussion in 'Technical Help' started by Cream_Revenge, Nov 18, 2017.
  1. just do it F.T
  2. Old school as ever @finm :upyeah:. Andy
  3. pulling my hair oot here. :)
    a quick google gave me yer 29nm, seems a bit low.
  4. FFS, if google and that article in the link says 29nm, then it looks like 29nm is good. When my Ducati manual says 45nm for the swing arm chain adjuster, I don't do it to a million nm cause folk think it's a bit low, I just roll with the 45nm cause it is correct.... :D Just Sayin..... :cool:
  5. well, considering an m10 wheel bolt is about 40-50nm that looks like at least m16 and when using a contact bearing. i wouldn't be stressed putting it up 60-70nm.
  6. Use a ring spanner to tighten, rather than a socket.
    Ring spanners are sized lengthways as well as for diameter, so they automatically limit the torque according to the size of the bolt. Nip it up gently but firmly and you shouldn’t be too far out.
  7. Fanny Tight? He already has :innocent: Is that tight enough, really? :)
  8. the stub is M10? not the wheel studs?
  9. Look, he doesn't know what answer he want's or, it appears, what he is asking so don't complicate it anymore :yum
  10. very few things in life are more complicated than a wheel still attached to its bearing flange coming through yer windscreen. just trying to put his mind at ease. :p
  11. Don't tell him that ffs :worried:
  12. Sorry, my mistake. The locking nut is a m16 1.5.
  13. Never have I seen something so simple made so over complicated by so many folk ?? Can't believe this ain't done yet, could have built the fecking trailer from scratch in this time. o_O
  14. Or a van, that would have been better :) (technical thread of the year award)
  15. 60nm. dont listen to the rest of yon amateurs. :upyeah:
    • Drama Queen Drama Queen x 1
  16. i know, and its one of my favorite words :upyeah: fil-an-jy filangy
  17. How does it spin with 50ft lbs? I have not seen a locknut setup on trailer bearings, only an axle nut with cotter pin to secure it. Also not sure about using thread lock with a locknut. I also don't typically reuse locknuts in critical applications as they are compromised when removed. Just my opinion.
  18. Freely :)
  19. That's good to know.
    When I take things apart I take notes or at least try to remember details to reference when reassembling. Lawnmower blade nuts are usually torqued to at least 50 ft. lbs. and take some effort to loosen. Trailer bearing nuts (those I've worked on) take very little effort.
