Triumph Scrambler 1200 Xe (2019) - Help
Discussion in 'Other Bikes' started by bigjimmyb, Feb 17, 2026.
  1. #21 chrisw, Feb 20, 2026
  2. Just looked at this further, looks like it may be for drawing/note taking. Although it has quite a good spec. Can always return it to Amazon if it is crap.
  3. If all of this is too much faff and you only need the error code read, then it cost me £40 to get my error codes read but this included have the service light reset for the hyper. Again though as my previous post i can't say if he has a triumph specific reader so worth calling first
  4. Yeah, sounds like either the starter switch or TPS could be acting up, especially with the cold cut-outs.
    I’d check the wiring on that LF indicator too, might save you a big dealer bill if it’s something simple.
  5. Thank you.
    Parts on order for a fuel system overhaul so we’ll see how that goes (doing it myself). I did think a TPS might be the cause but fuel lines and filters need doing so I’ll start there.
    I’ll check the indicator too while I’m at it.
    Cheers.
