I'm getting fresh tyres tomorrow, but I don't know the torque for tightening the wheel nut. I looked in the Multistrada workshop manual but I couldn't see anything for the single sided swinging arm version that the Pikes Peak has. Same goes for the front wheel axle. Please can someone enlighten me! Thanks in advance. [rubbish subject line, by the way - I meant single sided wheel nut torque. Tch]
If it's a big axle with 55mm nut, likely to be 230Nm. Front is typically 63Nm. Somebody with a manual will be along to verify hopefully.
63Nm front and 230Nm rear as @RickyX said. Remember to grease the threads with Type B grease (I use what is commonly called White grease but any good high temp grease will do). Andy
230Nm aligns with a couple of other references on a US Ducati site which I originally missed, and I did find the double-sided torque value (180Nm), so the 230Nm looks sensible. Thanks very much both.
