959 Wet Tyre Size
Discussion in 'Panigale' started by Danbolger, Jul 27, 2025.
  1. Do you lads that track/race 899/959/v2 run the 190/60 rear wet or the 200/60 as per British supersport?
    Cheerz
  2. IMO, stick with the 190/60. Andy
  3. Std 5.5 rim don’t go above 190. You would also run into swing arm clearance issues if it’s a v2.
  4. Thanks that what I was thinking. It was only because in British supersport they have to run the 200/60 wet pirelli. I've tried on a 200 and theres no clearance issues but I'll try to get a 190.
  5. More clearance with double sided swingarm then.
