Where Is The Power Supply For Satnav On Dvt Multi?
Discussion in 'Technical Help' started by firecat0_0, Oct 1, 2017.
Tags:
  1. I have been looking for the answer to the title question but I can't find the definitive answer on the search facility, so a very quick question, on the DVT model is there a SatNav power supply under left hand panel as it was on my pre DVT 2014 multi?
    Cheers
  2. You can sometimes get to it just by removing the emergency start button cover
    It's tucked in on left side by top
    You may need to remove the black left hand cover to gain access
    It's a connector with a cable coming out with ends heat shrinked to be able to join your leads to it
  3. What Simon said, its under the top left black cover
  4. Thanks both, much appreciated! On the 2014 it was behind the left cowl, the DVT set up looks a lot more accessible. Looks like I will be able to use the lead I made previously.
    Cheers
