748 Where Is The Redline/rev Limiter?
Discussion in '748 / 916 / 996 / 998' started by Rjkc600, Sep 17, 2015.
  1. Here's mine, done at 11.800 rpm [emoji15]
  3. Mine will go over 12k if I ask it to. The more important question is where is peak power generated, and that tends to be around 11k depending on engine. There's no point bouncing of the Rev limiter if you would get more power by shifting up earlier. Unless you're in top gear in which case you're probably out of road anyway
