WTD: Mikuni CV38 idle adjust screw please!
Discussion in 'Parts, Accessories & Clothing For Sale' started by 470four, Aug 28, 2012.
  1. Hi all, chasing one of the above? Or the thread type and length if someone can measure it please?
    Thanks! :upyeah:
  2. If you don't have any luck I'll pull the one out of my carbs tomorrow afternoon for you ;-)
  3. I somehow thought I would see this request pop up......:wink:
    The thread is very fine....only guessing I reckon it is something like an M5 x 0.5....length needs about 40mm, I think......I will have a look and see what I can find tomorrow (I have a spare body to try the threads in)....
    Failing that I suppose I will have to unscrew mine and measure it....Not.
    Actually, I have got a spare (which you aren't getting) in case my invention broke.....
    AL.
  4. it's good to have another reference - struggling with my eyes now to get the pitch but 0.5mm is correct and the diameter must be 5mm although the two screws I measured were 4.75/4.87 mm.
    So just to sum up :- M5 x 0.5mm pitch x 32mm long for the standard idle screw.
    I have used a Yamaha FZR 'remote' screw (like the one you have made AL.
  5. Agreed on the size.....just measured my spare....2.5mm is unthreaded at the pointy end.....but that's not a problem, easily formed if the thread is full length.
    Head is a crosshead type, but not necessary if joining it to the cable (but it does make it easier to keep the drill bit centred).
    In fact, it doesn't have to have a head at all if joining to the cable, but better if it does.
    I'll be having a rummage in several boxes of screws later....work is in the way at the moment.
    Update: I have found just one among a couple of hundred or so, but its only 12mm long unfortunately.
    AL
    #5 Ghost Rider, Aug 29, 2012
