Anyone using one of these (or like it)? https://www.amazon.co.uk/Vastar-Com...t=&hvlocphy=9045575&hvtargid=pla-797491200399 Seems a great idea and far less hassle than the usual small compressors as no need to access the battery.
No, but i have one of these and its very good. https://www.amazon.co.uk/Oasser-Inflator-Compressor-Electric-Rechargeable/dp/B075FLFT2P
I have one of the small orange , RAC branded ones ... works fine for occasional use, small enough and connects straight to an optimate SAE lead , so no faffing to connect assuming you have a lead already attached
Bought it. First try last night and total rubbish. Showing 3bar when it was less than 2. Changed to PSI showing something different again. Put a pound in, lose half a pound.... May be a calibration thing so have factory reset and will be trying again later.
To update this. easy enough to use, I had to factory reset to calibrate them it worked ok. Used about half the battery, according to the gauge, to go from 20 to 40 psi on a 19” rim. worthwhile for emergencies imho. Bit bigger than I hoped so I’ve got to find some way of storing on the bike. Now need to get a puncture repair kit and all good.
